I got a couple questions, I did the weber samari conversion on a rocketman adapter on a 88' carbed LX , but i am having issues , a little history , this car has been sitting for about 4 yrs, was parked do to carb issues and frustration, so i thought i would do the weber and ditch all the emission crap, and thats what i did, took all emissions stuff off, including egr, charcoal can.
here is the issue : coming off idle ,it backfires, i tried moving the timing(distributer) to all positions , stills backfires off idle and if you try and drive it, forget it its backfiring all over the place
my setup i had all vacuum ports plugged including the ones underneath the manifold, i had the both vacuum advances teed together and then tried one plugged the other hooked up , both setups are connected to the port under the choke on the carb, carb choke is wired to the original choke wiring.
i DID NOT disconnect the ecu/eca YET (dont know if that would cause the problems?) all the distributer wiring is hooked up as original EXCEPT one blk wire that is hooked to what looks like a 1" square 1/4" thick sensor on the exterior of the distributor fwd side( Where does this wire connect to?)
the thing idles really nice but when you come off idle it backfires , you can throttle on thru it and it runs smooth, but when back to idle and then try to come off idle again it will do the same, when the cooling fan comes on it idles down like it suppose to and no issues, but when trying to drive it , it can not take the load and starts to backfires to the point that it is undriveable
any help and suggestions would be greatly appreciated , Thanks Rick
, i blew out the rest of the exhaust with compressed air, put it all back together,,,, then i had to go be Santa, then back to work tonight, so i hope to try it out again in a couple days ,fingers crossed, figured since i had the car up on ramps i would go ahead a change the oil filter, oil. when the stores open back up
