Here's a test for the vast automotive knowledge base we have here at ff.com!
I have a 2004 Pontiac Montana that's giving us some grief at the moment.
- intermittent very fast idle speeds (2000rpm +), becoming more regular. At times the van will hold 50mph without touching the gas pedal :nightmare:
- IAC valve replaced last week. Ran OK for a while then reverted back to the fast idle.
- just started to run hotter than usual too.
- no check engine light
- all fluid levels where they should be
- even when idle is where is should be there is what can be best described as a rumbling noise when stopped at a light.
- I can get the idle back down for a while by removing the battery fuse for a minute or two.
- currently has about 365,000km (227,000 miles) on it
I plan on taking it to a McParts store in the morning to throw a code reader on it.
Any suggestions or diagnoses would be greatly appreciated
Thanks
Thanks
