94 festiva very delayed starting when warm
  • 94 festiva very delayed starting when warm
    I have a 94 festiva WB which starts fine when engine cold and fine when engine has only been off for 5 minutes, otherwise -from 10minutes until about 2 hours passes (after stopping running)it will crank over for about 10 seconds before starting. It always runs/drives fine once started. It's just the substantially delayed starting when warm that is the issue. I have replaced plugs, battery and coolant temperature sensor. ANY ideas are gratefully appreciated.
    Ya know, I had this problem in the carb'd Sprint for a while. Ended up being clogged fuel jets and a rubber fuel line that was literally sitting on the exhaust (causing the fuel to turn into a gas, causing a pocket that fuel couldn't get past [it's called vapor lock]). Only happened after a drive. Shut it off, no dice, no starting.
    Is your Festy carb or EFI? If it's EFI, then I might not have been much help.
    Good luck!
    -Joe
    White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
    1988 LX 5-speed
    ​​​1993 L 5-speed B8, E series, Aspire/Rio swapped
    Gone:
      His is an EFI. Any codes? No other issues other than delayed start?
      - Form should follow function...
