Rad fan
  • Rad fan
    Anybody know which direction the stock rad fan spins? Im hardwiring mine and need to know, it should pull air through the rad but it doesnt seem to want to turn that way.
    1993 Festy, 1.6SOHC, Aspire Suspension
    Stripped to bare bones, SCCA RallyX
    Yes, stock fan is a puller. You could get another motor from the junk yard if the bearings/commutator is worn.
    -Zack
      Reverse the wires right off the battery with jumpers and see what happens?
        Ya im using a jump box. Im getting more resistance with the pull direction but hopefully an inline fuse will be enough to prevent any issues
          There is a ford Taurus fan that is same size but better... I think it is 1999 and $25 new from oreiley's.
          Sent from my DROID RAZR HD using Tapatalk
          HULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
          "CL4P-TP" - 93 Festiva L
