Exterior lock rubber washer substitute
  • Exterior lock rubber washer substitute
    I found a good substitute for the rubber washers that always deteriorate on our external locks. It is in the plumbing section of the big-box hardware stores, where they have all the little rubber washers for faucets. It is called "Self-Forming Graphite Valve Packing", and comes as a grey rubbery flexible and formable rope, 3/32" thick x 24" long. Three of my external locks on Matthew didn't even have the stock rubber washers. I cut approx a 3" strip for each lock (driver door, gas filler door and hatch). For the hatch and gas filler I removed the locks to install, but for the driver door I didn't want to bother with doing that. I discovered that you can just push it in around the lock, with the lock still in the door, using a flat screwdriver to set it in place. Measure, cut, install took about a minute! I started with the middle of the rope at the top of the lock, and installed it down each side so the open end would be at the bottom.
    $3.00, and enough for two Festys. No idea about its longevity, but it's cheap and easy even if you had to do it annually. I suppose you could paint it with a clear paint and a small brush, for added weather/UV protection.
    Awesome work I was just contemplating using o rings just this mornings on my car locks.
      Actually, I went there looking for O-rings, but they didn't have anything that was thin enough in that diameter. So I got this stuff.
        Nice tip! I have had some luck cutting my own using some rubber gasket material from the parts store. Little time consuming though to have to remove everything first.
        - Form should follow function...
          Also I discovered that you can cut it with your thumbnail, so the only install tool you need is something to push it between the lock and the door.
            or you can still get them from mazda part# 022358962 about $1.50 online
            or you can get them from kia part# 0(zero)B45558494 about $2.00 online
              Cool guys
              -Greg
              Redneck Engineer
              FOTY - '09
                Didn't know that, thanks.
