Do you guys know of a place that sells new head bolts? Thanks, Jim
Where to get new head bolts?
Last edited by Pu241; 01-08-2014, 05:47 AM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
i thought you were supposed to replace headbolts on a rebuild since the old ones might've stretched. the bolts and washers are still available from USA KIA and MAZDA dealers.
KIA - part# MB630 10 135A. about $6. (WASHER is MB630 10 138A). MAZDA - part# B630 10 135A. about $12. (WASHER is B630 10 138A).
The head bolts can be re-used. But if you plan any power upgrades like a turbo, you might want to go to ARP studs.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Yup. You can reuse the old bolts on these, as they are not TTY, Torque to Yield. Many other engines use TTY bolts, but not ours. Clean them up real good, and use them again!Contact me for information about Festiva Madness!
Jimdigs!
Somebody just brought up an old thread about head bolts! There is a place memtioned on page #2 of this thread. Maybe you can get the bolts through them still
Here
http://www.fordfestiva.com/forums/sh...nding-problemsDan
Originally posted by Pu241 View PostWhy do you need new head bolts or is this another "what is all this B3 B6 stuff" question?
http://www.fordfestiva.com/forums/showthread.php?12904
Originally posted by jimdigs View PostWhat do you mean by that? I truly didn't know what it meant. Excuse me for bothering you.
Seriously, I didn't expect you to know about the head bolts, most are TTY.
And I did supply a link so you knew why.
But a little reading and the context alone would have told you what a B3 and B6 were.
BTW it is customary to put your location in your profile, someone may be kind enough to send you headbolts, if they know your not in Siberia!'93 Blue 5spd 230K(down for clutch and overall maintanence)
