The white festy is so close to being back on the road but its having a weird electrical issue. My guess is some kind of a voltage issue. It will be running then every will sporadically like go dim (like its no longer getting enough juice). My dash lights headlights and lights on the radio. Then if I turn it off when its like that it won't crank back up. The battery terminals are terrible and need to be replaced as they don't make a tight connection could this be the source of my problem? Gonna replace them today and find out.
The battery and alternator are new replaced by the PO but I guess I can't rule that out either.
Its almost like there is a short somewhere as sometimes it will jump right off and others even after being on cables for a while can't even get enough juice for the radio or dash lights or anything to come on.
