they dont make em anymore, what do you guys do if one breaks (like mine) ???? anybody got some for sale ???
parking brake cable
^^ Look for them on festivas in junk yards. I got lucky and pulled one for mine off a Festiva in a junk yard. I even needed brake adjusters which I got also. The whole brake cable system is easy to remove from a Festy.1993 Ford Festiva L blue 170,000 miles
1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
1995 Ford F150 XLT black 203,000 miles
2002 Honda CRV silver 180,000 miles
2003 Toyota Rav4 Sport black 94,000 miles
2008 Sym Rv250 dark grey 30,000 miles. My scooter.
1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
Mike
Yeah, its the reinstallation that's going to be a PITA! LOLOriginally posted by muleskinner View PostThe whole brake cable system is easy to remove from a Festy.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Also, don't go for a drive up Market Street in San Fran in the middle of rush hour.Last edited by bravekozak; 01-10-2014, 07:31 PM.
Originally posted by Chobobulous View PostMy e-brake has not worked for 2 years now. Well it kind of engages when you pull up all the way.
Just find somewhere flat to park and leave it in 1st.
Cheap fix.
They can be fixed for very cheap, using parts from Lowes.
Depending on were your cable broke, usually on the passenger side guide which hold moisture and the cable rusts through/snaps when engaged.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Its not broke. Im pretty sure its just streched. I think that if I tightened the middle part it would work again. The tightener is just rusted real good.Originally posted by Pu241 View PostThey can be fixed for very cheap, using parts from Lowes.
Chob, Have you already tightened the adjuster on the e-brake handle all the way? And loosened the pivot points inside the rear drum?
As far as the OP is concerned - you can get them brand new from fourgreen. http://www.fourgreen.com/store/scrip...T-p-KK15344150
Double check the part # on that.... and I'm not sure how much shipping will cost you. But I'd love to buy a brand new one from them, if just to have it on hand.
Before fourgreen popped up it was impossible to find them new, and sometimes they would get pricey on e-bay etc. I've sold them for >$80 before. I have an extra one but I'm inclined to keep it, unless you want to pay me more than it would cost for me to buy a new one from fourgreen :p~Nate
Current cars:
FOTY 2008 winner!
Ive tightened it up at the handle all the way. Never got around to ckecking the pivot pointOriginally posted by skeeters_keeper View PostChob, Have you already tightened the adjuster on the e-brake handle all the way? And loosened the pivot points inside the rear drum?
Yea pu
, thats what happened and I gotta have one for a NC inspectionLast edited by stonemaster; 01-10-2014, 10:50 PM.He said a bad word :nono:
1990 Festiva
1987 F-250 diesel-powered
1984 Ironhead Chopper
1999 Ducati Monster
If you use the search feature you will discover that FourGreen sales out of Korea still stocks all manner of Festy parts and you will not be able to beat their prices. It's a bit convoluted to deal with these people (you have to use a Russian parts manual to identify what it is you need (parts numbers) and Festys are referred to as Prides and Mazda 121s outside of n. America, but for sure they will have what you want.Originally posted by stonemaster View PostWe rigged it with a couple of cable clamps for now but I wanna be ready for next time
I see in the above posts, that no one has messed with the pivot in the rear drums!
This is an important piece of the E-brake system. The pivots get rusty and freeze up, thus doing exactly as desribed in above posts.
Take the rear drums off, remove the pivot parts, clean them as best you can, put the pivot in a vise and then take a hammer and tap around sideways on the pivot until it gets free. There are 3 pcs to the pivot, get them to all pivot freely. What you are trying to do, is spread the rivet heads that hold the 3 pcs together, just a little. This will free up the pivot pcs so they can move. After they are free, grease the heck out of 'em and re-install.
Voila! A working E-brake! You will be astonished at how well they work after this is done.Dan
That presumes you have an intact cable from front to back and side to side. But you are quite right; the pivot point of the brake adjusters inside the drum (on both Festy and Aspire versions) on my cars have to be freed up at least once a year. Which means clamping in a vise and using a hammer or large pliers to move the arm until it's unseized again. At same time is good idea to free up the toothed 1/2 adjuster wheel; they've often become stiff too.Originally posted by drddan View PostI see in the above posts, that no one has messed with the pivot in the rear drums!
I installed the one I took out of the Festy in the junk yard with no problem. I greased up the cable & fished it through the floor first, connected it to the brake handle, then installed the rest of it all the way to the adjusters, that I also got from the same Festy. Ta-da!!Originally posted by Pu241 View PostYeah, its the reinstallation that's going to be a PITA! LOL1993 Ford Festiva L blue 170,000 miles
Mike
