Sigh. Sorry to ask what should be a simple question, but I've spent 2 hours bleeding the '89's brakes. Still straight to the floor.
About 2 months ago I replaced both rear cylinders, and bled the brakes. They felt nice and strong, so I thought yay I did it right.
Go on about a week later, the pedal travel got a bit more (so I knew I messed up somewhere), but it was 15F temp outside, and the travel wasn't too bad. I left it alone until yesterday.
It went from 1 inch travel, to no brakes. The brakes do not leak fluid at all. I had my mother pump for about a 1/2 hour+, bled everything, only got a little more strength once or twice. Fluid is squirting out, I wasn't seeing much air at all.
After that didn't work, I fashioned a fuel hose + mason jar with fluid, and saw a little bubbles. I bled all sides until the bubbles stopped/brake light turned on + filled back up. Wasn't seeing any air come out of rears, did front right, no air, did front left, no air..
Tighten it all back up, STILL NO BRAKES.
It's 30 degrees and I'm definitely not roasting my chestnuts out there.
Anything I'm missing??
-Joe
-Joe
