Hey guys, I know this is a Q about other than a Festy, but I also know there are some pretty smart folks here!!
So maybe someone can guide me in the right direction about a misfire on the girlfriends ford ranger.
I think she has a bad coil pack, but I want to ask you guys.
Ok ... pertinent info...
2001 ranger
3.0 vulcan 6 cyl
what I have done so far
pulled wires, checked with multi meter(ohms), all wires looked good ..got readings on wires
started engine, pulled one wire at a time from coil pack ...#4 cyl not firing
replaced spark plug on #4..... still not firing
tried to check coil pack with meter. Haynes says to probe center connector and outside connectors, but that sounds like 3 connectors ..I have 4connectors
book says should be 5.0 ohms or less ...probed all connectors in different configurations. all read less than 5 ohms
What gives ...bad coil pack?????
coil pack is about $80..dont want spend good money, if coil is not the issue
Thanks in Advance!
Dan
PS ...doing some thinking ....maybe an intermittent short in #4 plug wire?
i'll check that while I wait for an answer
2001 ranger
3.0 vulcan 6 cyl
Thanks in Advance!
Dan
