Hello!
I tried to use the search, but by virtue of the fact that not very well know English slang, found nothing.
Short history:
I cleared cooling system and radiator heater. Under the hood, remove only thermostat housing, and distributor cap. When screwed back the thermostat housing, it successfully broke.
I ordered a new. While waiting (2 weeks), car stood in the garage, the temperature was below 0 Celsius.
When all put together, run the engine. Runs fine, works normally 5 seconds, then lights "check engine", lights up for 5 seconds, then goes off and the engine runs as if one cylinder is not working. Here this term I do not know how to English
If drown and then run - immediately begins to run poorly, but the lamp is not lit.
If disconnect the terminal, and after few minute turn - the same thing that I described at the beginning. Ie a few seconds works fine, then check ....
In this case all of the exhaust naturally horrible smell and the sense of one or two non-working cylinders.
Tried to press the acceleration pedal several times. It's nothing.
Tried to warm up a bit, but for 5 minutes, nothing has changed. Then it was impossible to breathe.
All high-voltage wires checked, cleaned the distributor cap, distributor slider cleaned.
Candles have not watched, and the error still can not be read.
What are thoughts on this?
On the Ukrainian forums found one of the probable causes, what bad gasoline. Although refuel a long time, at the same gas station.
But why then it works fine a couple of seconds?
Short history:
