What's next?! Won't start!
  • #16
    Counterclockwise.....sorry
    • #17
      Ok I checked the firing order... It was right I hoped in and tried to start it... It fired right up and ran for about 15 sec... Now it won't start again.... Ugh
      • #18
        I was having the same kinda problem and put on a new coil and she started right up.
        • #19
          Well I think I have found my problem... I'm not getting fuel to the rail full time... It's temperamental and only works sometimes... Would a fuel pump relay cause this? What could it be??
          • #20
            Pull the hose off and watch while you run run the pump into an empty gas can. See whether or not the pump is tired. Also check for blockages. Good luck.
            • #21
              Also it only runs when I have it jumped under the hood with the test port.
              • #22
                You bypass the VAF when you jump the fuel test connector to ground.
                Fix the VAF. It's for your safety. Otherwise, your fuel pump will not shut off with your key in RUN and the engine not running.
                • #23
                  Dang that's a bummer!! It's a brand new VAF!
