Hello Guys! This is my first post here, I am a happy new Festiva owner! I purchased a 1991 Ford Festiva 5 speed a few weeks back and have been driving it since. The owner before me had kept up with the maintenance quite well recording oil changes, timing belt changes, tires etc (has 262k miles) The car runs and drives great but has had a ticking sound since I bought it. I searched the forums a little to see if this same question has been asked and I did not find an answer, if this has been asked, I apologize!
Ticking sound
The ticking sound is transmission related, not engine. While driving in any gear with low to medium load on the engine, I can hear a constant ticking. If I let off the gas even slightly so there is VERY low or no load on the engine, the ticking stops, if I press in the clutch, ticking stops, if I put it in neutral while moving, ticking stops. I can't tell for sure but it seems like at higher speeds (45+ the ticking sound is gone). I have put over 1000 miles on it since I bought it and nothing has changed still drives fine, shifts smooth, clutch doesn't slip and has the correct amount of transmission fluid. Last off, the ticking is consistent while going straight or turning, does NOT tick in reverse.
I am going to get a video on my way home from work tonight, hopefully someone has dealt with this before. I plan on putting in a new timing belt and a few other things this spring/summer, I would like to fix whatever this ticking noise is while I am at it!
Thank you in advance for any help!
Ticking sound
