My festy engine (help?)
  • My festy engine (help?)
    I know the pics seem kinda dark( it's 11pm Mind you ) but maybe you guys can tell me what needs replacing or how I'm I good wise on the motor and is it stock thank you if not what motor could it have been swapped with?image.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpg
    This is my festiva, there are many like it but this one is mine':fred:
    Moved to the proper section
      Thanks wasent sure where to put it
        Unfortunately, pictures can't tell anyone how an engine runs or what needs replacing. It appears to be an untouched factory B3 1.3L SOHC motor. Were you provided with any service records or maintenance history when you purchased the car?
        1988 Chevy Sprint Turbo 997cc
          Not really I mean it runs like a champ no leaking or anything of that sort the weird thing it's a 4 speed not a 5
            But when I first got it ran but it hadent been maintenanced since 08 I fixed all that and now it runs good
              Perhaps the transmission was swapped from an older model Festiva then.
                Looks damn clean to me.
                  Is there something wrong with it? If it isn't making weird noises and is running fine.... then it is probably fine! I'd change all the fluids since it had been sitting a while, but sounds like a nice festy! And like I mentioned in your other thread, someone must have swapped a 4 speed transmission in your car. My 91 was like that as well.
                  My Musica! Click me!
                    Thanks peps! Yea not at all actually is super loud and clean and I've already changeed fluids along with parts gonna do a swap soon!
