What's that noise?
  • What's that noise?
    To be more specific I have a horrid noise coming from the front drivers side wheel. Strangely only makes noise as I turn the wheel. No noise when going straight. I was thinking wheel bearing but the sound only when turning makes me think otherwise, like cv joint, axle stuff, obviously Im lost when I go past the wheel and brake rotor. Help me guys! Sounds like.... popping,cracking, rattling, oh now I sound like an old lady at the car shop! Hopefully the fact that it only makes the noise as wheel is turning maybe you guys are already knowing what I need to look for.
    CV joint. You can buy the complete axle shaft at your local auto parts for around $60. The Haynes manual has the entire procedure to replace. I do both sides....one at a time.
      I got under and took a look and my cv boots are ripped wide open. Thanks dalebwilson for responding so fast. Just wondering should I even move this car at all until I replace or will it be okay since I'm going to replace axle halves? I was thinking just moving it in the yard. I will need to move it to a level spot before I put it on jack stands.
        You're welcome. It will be fine to move. After you safely have it on jack stands and off the ground, grab the front tires at the 6 and 12 o'clock positions and rock back and forth. If you have looseness or movement, your wheel bearings will need replaced as well. These are also prone to failure.
