Turns over but takes longer than normal...
  • Turns over but takes longer than normal...
    A few weeks back my car would not start at all. It had spark and gas and would crank but not start. I changed the coil and ever since it has started. Was just wondering why it doesn't start quick like it used to. It cranks about 3 times then starts. I have changed plugs, wires, rotor, cap. Any ideas of the slower starting? Thanks
    Jim: Have you checked your ignition timing? This can cause slow starting.
    -With the ignition off, ground the self test plug (ST1) located near the brake booster. It is a single pin black connector.
    -Warm up the car
    -Set idle to 700RPM
    -Check timing marks on crankshaft pulley with timing light connected to the #1 spark plug wire.
    -#1 cylinder should be firing at -10BTDC. The lower timing cover will have a "10" reference mark on it to indicate correct setting.
    "Fred" 93 Festiva L B6-ME Swap
    “Though he is small, he is but fierce.”
