Diagnosis:
Partial throttle and partial spool
RPM and load varies
Any gear from 2nd-5th inclusive
Very quick stutter between 0-2psi on the boost gauge
Progress:
Voltmeter reads a steady 14.7/14.8 volts at full load/operation.
Plugs cleaned and gapped to 0.031".
Cap and rotor cleaned and dried out.
Checked base ignition timing and coil resistance.
Checked air filter and new fuel filter.
Got the steadiest 22inHg I've ever seen.
Next steps:
1) Reset the ECU.
2) Fill up with fresh 91 octane.
3) Air blast electrical ignition components.
4) Delete boost controller temporarily.
5) Check the function of my blow off valve.
From there, I'll likely be building a boost leak tester and buying a fuel pressure gauge. Any thoughts?
RPM and load varies
Progress:
Next steps:
1) Reset the ECU.
