Like the title says im looking at a 91 festiva with 171k. what should I be looking out for? Any common problems? Thanks in advance.
im thinking about buying a 91 festiva
Look at the bottom for rust. Especially in the rear beam mount area and under the door jams.
What area are you located in? Northern cars are more prone to rust than those down here in the south.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
That's good, CO doesn't use salt. 171K is no prob if it's been taken proper care of.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Ok I just looked at and it has no rust. She said the prevous owner had it sence 95 and had the motor replaced. The engine looked realy clean and had what looked like a brand new alternator. It did have some erosion on the battery anything I should look out for with that?
Without knowing your knowledge of Festiva's, if you work on it or have ANY right rear work done on it, remember that the right rear axle nut has LEFT handed threads. The rear axles are getting hard to find if the threads should get stripped. Sounds like the battery terminals just need cleaned. Can you get any info on the maintenance done on the car?
That would give you an idea of whats due next and how good it was taken care of in the past.Jerry
Team Lightning
93 L Lightning. BP
She didnt have any papers on work done or anything I have never worked on a festiva but have dont extencive work on difrent maks and models. I wont be paying alot for it but the oil looked good and filter looked new she said her father in law maintained verry well and is selling because she is expecting and just got a bigger car.
Nice!! Just be aware of that right rear axle nuts backward threads.Last edited by Team Lightning; 03-12-2014, 08:31 PM.Jerry
Team Lightning
93 L Lightning. BP
