Hello all,
So, managed to cause some damage to my 5 speed 93 Festiva Transmission. Always kept it topped up with fluid, and changed it when I first bought it. No leaks, ran good overall except for the occasional grinding into second gear.
Lately, it had been acting a little strange when I would shift into fifth or third. It would act like it was hitting the edge of the gate (I don't know if I am using the terminology correctly here... I still don't quite understand what gates are.) instead of going into gear. I would bring it back to neutral and then push it back and it would usually go into gear. Well, I ended up having it fail completely driving home a few nights ago. I went to shift into Fifth gear and it just wasn't there. It felt like it was go to far to the left as well. Almost like it was going outside of it's normal channel of travel? Third gear also refused to engage. I could get it almost in gear, but it would grind and I just couldn't get it to stay. Fast forward the next morning, I could seem to get it to go into gear in third, and if I played with it just right it would finally go into fifth. But for the most part, fifth is pretty much gone. It almost feels like it isn't going far enough forward into gear? I looked underneath and all my linkages are good. I even unbolted the arm that connects the transmission to the engine (with the bushing... can't remember the name of it right now) and tried to see if it made any difference, but same issue. It also started to give me some real problems that way. I had a hard time getting it out of gear occasionally, and it wouldn't go into gear then suddenly it was fine.
Anyone able to tell me what they think I have done? I don't think it is synchro's based on what I have read about them, especially two gears seemingly effected at the same time. Are these the gates going bad? Is anyone able to point me anywhere that has some more info about what these are and how to fix them? Thanks very much for your time.
) I really was hoping something was off on the linkage, but everything is right.
