For about a month now.....
  • For about a month now.....
    The battery light comes on and off every now and then on Shadow. I have looked over it several times and can't find anything wrong. Could it just be a loose wire or corroded wire? The altenator is making some noise but its fairly new too. The car starts up normal everytime.
    Thanks.
    1993 Ford Festiva L blue 170,000 miles
    1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
    1995 Ford F150 XLT black 203,000 miles
    2002 Honda CRV silver 180,000 miles
    2003 Toyota Rav4 Sport black 94,000 miles
    2008 Sym Rv250 dark grey 30,000 miles. My scooter.
    1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
    Mike
    Originally posted by muleskinner View Post
    ..Could it just be a loose wire or corroded wire? The altenator is making some noise...
    yes and hmmmmmmmmmmm
    -Bryant
      I got the battery light when the fuse links were giving me issues. Get the long leg fuses and jam those in there or better yet, take it apart and clean all contacts and then install the fuse upgrades. It WILL get worse, to where youll have no power for starting system and be stranded. when this is happeneing, i guarantee if you try to pull the fuse links out they will be too hot to touch.
      1993 GL 5 speed
        Some auto parts stores will test alternators and batteries for free.
        If the belt were slipping you'd expect to hear noise but you could
        check the belt tension with a ruler. If you have a voltmeter you
        could check the charging voltage at the battery while the engine is idling,
        about 14.5v.
          i ran an auxillary wire from my battery to my alternator charge state port. the alternator has to reference the battery voltage to be able to put out an appropriatly voltaged charge, any time this isnt making connection the battery charge light will come on, as will any time the alternator isnt putting out voltage.
            2008 Kia Rio- new beater
            1993 Festiva- Fiona, DD
            1997 Aspire- Babyspire, DD
            1994 Aspire - Project Kiazord
            1994 Aspire- Crustyspire, RIP
