I havr a 91 and I can't get the plugs out. Im afraid of breaking them. Any advice?
spark plugs are realy tight
Fire up the car and let it get warm, not hot warm..
Then spray them with BP Blaster® using the red tube to deliver it direct to the threads.
Let soak and spray them again.
This generally, works well.Last edited by Pu241; 03-16-2014, 05:21 PM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
So why do you let the engine get warm, but not "hot warm"? The warmer temps should expand the spark plug body/threads but wouldn't the warmer temps also expand the block more, too?Originally posted by Pu241 View PostFire up the car and let it get warm, not hot warm..
Then spray them with BP Blaster® using the red tub to deliver it direct to the threads.
This generally, works well.88L - 'Twistiva' - 'The Fusion of Man and Machine'
88LX - 'Laztiza' - Future Resurrection Project
91L - 'Mistiva' - My Daughter's DD
93L - 'Vextiva' - Airport Car
Penetrating fluid can produce pretty noxious smoke if it gets too hot. The spark plug is not made of the same material as the aluminium cylinder head, which is why the slight amount of thermal expansion is desirable.Originally posted by Twistiva View PostSo why do you let the engine get warm, but not "hot warm"? The warmer temps should expand the spark plug body/threads but wouldn't the warmer temps also expand the block more, too?1988 Chevy Sprint Turbo 997cc
And oddly enough, I find first attempting to tighten the offending plug/bolt/nut tends to work better.
But you need to take care and not snap it, just want the tinies bit of movement.
Then try loosing it.
Once it breaks loose hit it again with the PB Blaster® and working it alternately tighter and lose.
Remember the head is aluminium and the plug body is steel.
You do not want to gall/crossthread the threads in the head.
Much badness when that happens.
BTW, yes noxious fumes are part of it, getting burned is nother part, but mostly the expansion rate of aluminium is larger than that of steel and so does not require as much temp to get the expainsion differential you are wanting.
Reiterate the use of anti-seize upon plug install.
Good luck!Last edited by Pu241; 03-16-2014, 05:19 PM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by Aaronbrook37 View PostPenetrating fluid can produce pretty noxious smoke if it gets too hot. The spark plug is not made of the same material as the aluminium cylinder head, which is why the slight amount of thermal expansion is desirable.Thanks for the explanation, guys! Definitely good to know.Originally posted by Pu241 View PostAnd oddly enough, I find first attempting to tighten the offending plug/bolt/nut tends to work better.
Good luck!88L - 'Twistiva' - 'The Fusion of Man and Machine'
Glad you got them out OK. Years ago ,1995, I was going to change the plugs in my recently purchased used 92 Festy with about 50K miles and one snapped off in the head while barely touching it. The body of the plug had badly rusted plus the threads were frozen in the hole. After trying the usual PB blaster and EZ outs, I ended up taking the head off, drilling thru the plug almost to the threads, making four or five cuts thru the threads with a saber saw blade, then prickpunching out the pieces. Probably ought to take out the plugs once a year, check for rust, and apply fresh antisieze compound .
Are the spark plug at the max?
Ill say if you have a tiny bit of thread left, you could get away with going forward (tighten) to "crack" the plug a bit and then go back (loosen)
But by the way you're talking, sounds like they're tiiiiight.
Sent from the depths of hell.Last edited by jawbraeka; 03-20-2014, 05:08 AM.Ford Festiva 1991 WA Model (5 Door)
Avg Economy:
Highway - 7.32L/100km
City - yet to be determined.
