..so I did a search and found helpful info. I went out to the car and pulled the wire to the relay in the thermostat housing with the key in the on position and the fan started like its supposed to. Earlier today I ran the car for about 20min. and the fan never came on, which is why I did the searching on here. The upper hose was nice and hot, the bottom hose took longer to warm up. So now that I know the fan is fine how do I know for sure its the relay gone bad or just that the temperature in the engine never made it to where its supposed to. My coolant is nasty and I do need a flush. I just bought a multimeter can I test the relay with it? I'm just learning with the multimeter and don't want to short anything out. I bought the multimeter to check my tps (throttle position sensor) but am waiting on a wire piercing probe. Anywho, anyway to check to be sure the relay is fine? thanks, Jim
Another fan relay question....
From my understanding in the search if you unplug the senser at the thermostat housing and the fan comes on and your still overheating, then you have a bad senser.
Of course having nasty radiator fluid doesn't help either. I'd try flushing the system first & putting fresh rad fluid in.Last edited by muleskinner; 03-22-2014, 09:46 PM.1993 Ford Festiva L blue 170,000 miles
1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
1995 Ford F150 XLT black 203,000 miles
2002 Honda CRV silver 180,000 miles
2003 Toyota Rav4 Sport black 94,000 miles
2008 Sym Rv250 dark grey 30,000 miles. My scooter.
1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
Mike
I'll try flushing first. Gotta wait for the temp outside to get a little warmer. Still cold up here in southern Michigan.Originally posted by muleskinner View PostFrom my understanding in the search if you unplug the senser at the thermostat housing and the fan comes on and your still overheating, then you have a bad senser.
