Hey I'm new to the forum. I had a 89 Festiva once and convinced a broke friend of mine to get one since gas prices are outta here and now it's in my custody while he gets the papers. So I chose the name Festiva Real, to match the spanish name. Pronounce it like Real Madrid the futballsoccer team. I thought I'd fix it up some but ran into some impasses. Hopefully you guys can help me.
It's a 92 GL 5 speed without ac, without tachometer.
#1 When pushing it down the driveway my mechanically genius g/f threw up the hand brake when I told her to push the brakes. The hand brake now seems frozen but just the right front tire is stuck. It's not stuck so bad that I can't turn it by hand but trying to go in it is rough. I discovered this anomaly by jacking up each tire, one at a time. Now here's the hitch I can't unbolt the tire to check out the frozen brake because my +cross wrench doesn't have a socket on it small enough and the bolts are on so tight/rusted I don't want to force my only socket wrench into breaking. (I did this with my last socket wrench on the last festiva). So what is the remedy to a frozen/broken hand brake? How much is a brake job for all 4 wheels + hand brake?
#2 The trunk latch is damned. It's damned stuck. I have no idea how to get it to pop. I turn the key right something moves, pull the latch nothing. Vice versa nothing, Yank yank yank. I poked it with a screw driver, hopped on the back bumper singing the low rider song, nothing. I unbolted two bolts hoping that if I could just get the door away from the car I could figure out what's wrong with the latch. The latch still refuses to part with the door and the car. It's engaged in a death grip. Anyone have any idea how to pop a trunk latch when the conventional means don't work?
#3 I was told the catalytic converter is clogged? Has this ever happened to anyone here? Where can I get the cheapest/best replacement without tossing $400 out the window at a muffler shop?
#4. Help. I'm used to fixing cars the conventional way with bolts that turn and latches that open. The festiva has won this battle but I want to win the war of making the sucker in great shape. This thing reminds me a of stubborn mule you're trying to lead to water.
