Fuel tank ?
  • Fuel tank ?
    My 88 should have the same fuel tank as 89-93 or did they change it up?
    88 - 89 carb tank (smaller hole) is different from an 89 - 93 EFI tank (larger hole). Different pickup assembly.
      Ok thanks, just got to make sure I buy the right one
        FYI, the '89 to '93 FI tank is also the same as all 2 door Aspires. The 4 door Aspires had a different tank from the 2 doors.)
        Karl
          If you need a new tank, you can get a new one for just under $100 shipped to your door.
