Now that I got both brand new control arms installed, I now have a weird pulling to the right which happens randomly, nothing seems to trigger it. The car will be tracking perfectly straight, then it will randomly pull to the right all of a sudden, almost as if someone pulled the wheel slightly to the right. I am no longer comfortable driving highway speeds with this.
I used string to check the alignment, everything seems to be square, except the rear driver's side does have a hair of toe-in.
I have checked, and I see none of the bolts were loose. Only thing is the sway bar bushing on the control arm on the passenger's side didn't get centered quite right, but it is in there nonetheless and bolted down tight.
I am afraid that now that the suspension components are nice and tight now, that they may have causedplay in the steering rack to become more aparent.
What do you guys think?
