Hey guys, I am changing out the fuel tank on my 88 festiva. I got the old tank out, and ended up breaking off two rusted out hose ends. Problem is I haven't the slightest idea where these hoses went to. I can't find any place that they broke off except from the tank itself under the big filler hole. I will post pics, but it looks like on the old tank there are two connectors under the filler hole, but on the new tank they're not there. I ordered a carb tank so unless they shipped the wrong one it should be right. The hole on top looks the same, and I think for an efi it's a bigger top hole. The first one that broke off was zip tied with the other hoses running down the side of the car by the fuel fill tube. It went down right under the filler hole. The second one that broke runs to the front of the car with the brake lines. I'm pretty sure this also ran up to right beneath the filler hole. Would these two possible have been connected and somehow ended up fused to the tank? Thanks
These two pictures are of the first one that broke off
