Does it matter what type of wire you use to ground it if you do use a wire? I just want to make sure I know what I'm doing, don't want to short anything out. Thanks.
How do you ground the sti connector
No, just make sure you have the correct wire.
I use a big paper clip.'93 Blue 5spd 230K(down for clutch and overall maintanence)
No, I stick a big paper clip into the connector, then ground it to whatever nut/bolt is convenient and easy to back off and re-torque it down with the paper clip trapped under it.'93 Blue 5spd 230K(down for clutch and overall maintanence)
I leave a male connector permanently in the STI connector, then use a wire with an alligator clip at each end to ground it. Very convenient.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Whoops I type to slooooowLast edited by nitrofarm; 04-12-2014, 06:06 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
After a couple of shocks...LOL...I grounded out the sti and the engine immediately slowed down. Is this normal? I then checked my timing buy having the first notch (which I painted white) line up with the pointer thingy (which I painted white). It was off a bit so I loosed the distibutor and moved it til I got it as close as I could to lining all up. Its off a smidge to the rear of the notch. I believe I just set my timing? Best I could anywho. Everything sound right?Last edited by jimdigs; 04-12-2014, 07:04 PM.
You want to ground it BEFORE you start the engine but it shouldnt matter to much. But you want to adjust base idle speed & base timing together for it to be perfect. And yes you just set base timing. That grd locks out all electronic advance.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Originally posted by nitrofarm View PostYou want to ground it BEFORE you start the engine but it shouldnt matter to much. But you want to adjust base idle speed & base timing together for it to be perfect. And yes you just set base timing. That grd locks out all electronic advance.
Originally posted by jimdigs View PostI was just following the sequence in the manual..states to..Start the engine and allow to warm up...next step states....ground the single pin black, Self test inuput test connector.
Originally posted by jimdigs View PostI have no way to check the idle speed. With the STI grounded it sure idled a lot slower, is that normal?Last edited by nitrofarm; 04-12-2014, 11:55 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
"Before I adjust the idle speed,I always observe what the engine idles at after two or three fan cycles. When they get really heat soaked they will sometimes idle to low."
My fan is not cycling at all. I am going to flush my coolant system today (real nasty and rusty) and if that doesn't help with my fan coming on (because it does come on when unplugged from the sensor in the thermostat housing) I will have to get a new switch/sensor thingy that is in the housing.
