I have a complete set of new Festiva shocks. Can I install them with the Aspire suspension conversion? Or will they be too low for my 14" rims and tires?
Suspension question
Brave the only problem you should have is in the rear. You'll need Aspire rear shocks because the spring perch is higher for tire clearance. Assuming that you dont want to do a custom shock in the rear. But if you do here is a great setup Rear Coil Over 2.0Last edited by nitrofarm; 04-12-2014, 06:34 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
And only the Monroe shocks/struts are different from festiva to aspire. Gabriels are the same number for both the festiva and aspire at least at Autozone.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
