So I swapped over my bp to another festiva that was auto and I added the g series trans. We got it all mounted and Im using the harness that was working fine even after the car crashed. it will still start with it cause would start it everyday. I removed my passive restraint module and depinned some wires but I dont think that would do anything to the cranking of the engine. I removed the inertia switch to and grounded the grn/wht wire. My headlights work but nothing else does. I got power to the starter and to my fusible links. Theres some extra plugs hanging around but theres nothing they plug into to. Im looking at wiring diagrams now of the car to see if it all has something in common. I must be missing something. Any feedback is much appreciated. Mahalos!
BP no start/crank Help!
I had an issue once where I didn't wire/jump the neutral safety switch on the trans, and it would lock out the starter, it wouldn't crank. Maybe something to look into?1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Thanks rocketman but I found out it was my fusible links! But now I got it started and i felt my headers to see if the cylinders were dead and cylinder 2 & 3 are cold and cylinder 1 and 4 are hot. but it idles smooth and theres spark at cylinder 2 & 3. the fuel injector connecters are getting power too. What you think? Thanks
