I can't for the life of me figure this out.
On my B6 swap, the idle is quite high. (around 1200-1300 rpms) and at the same time it lopes by about 50rpms, and when trying to adjust the idle lower (Around 800 RPMS) it lopes by about 100-250rpms and idles really rough.
I have tried looking for vacuum leaks by soaking every single possible opening for extra air to get into the system, and can't find anything. I even sprayed the ducting in case of cracks.
I tried swapping in the B3 ecu and VAF, and mix and matching them, nothing changes.
Checked the cooling system for air, so I popped the radiator cap and topped it up and started it, no air bubbles at all even when squeezing hoses, and it got up to operating temps too.
Tried unhooking the IAC, wouldn't even stay running.
Tried tapping the IAC valve to see if the idle changes, nope nothing.
Listened to the injectors using a screwdriver stethoscope, injectors sound fine.
Only thing I can think of is maybe ignition system, but the coil and ICM worked fine on the B3 and didn't show any of these symptoms, and Zoom Zoom said the spark Plugs, wires, and dizzy cap are fairly new.
Now I don't get a check engine light on the road, but grounding the STI it does blink a code for the purge solenoid. But we removed that during the B6 swap and plugged the line coming from the tank with a bolt, also I don't even see a connector for it on the injector harness on the B6. But parts lists clearly state that the 80s tracers had a purge solenoid. But I don't see how a emissions thing like a purge solenoid would even matter in this case.
I am completely baffled.
