So once again the bird has fallen and can't get up.
I turn the key and she turns but just won't start. I've replaced the dist cap and spark plugs. I stuck a screw driver and got a spark all the way down.
I thought it might be my fuel pump. So I sprayed starter fluid in but it didn't start. Even if the fuel pump is bad that should still work right?
Other than that I've been working on the cooling, replaced the Thermostat and seal Just added 50/50 antifreeze today.
I'm out of ideas...
1993 GL Fuel Injected
I'm out of ideas...
