How do you tell what degree you are at as far as timing goes...
  • #16
    Originally posted by jimdigs View Post
    So I got a multimeter with a rpm kit and set my rpm and then rechecked my timing all is well. My rpms were pretty low with the STI thingy grounded, around 500 so I had to adjust that to 700 like the manual states. Timing stayed good.
    Excellent, try after the car has had plenty of time to get hot.I like to wait for the cooling fan to go on.Then after it goes off, I shut off engine & ground STI and then set timing.I seem to get better results with a heat soaked engine.
    • #17
      Funny you should say that. I had the car running while checking the rpms and the fan kicked on, so I disconnected and waited for the fan to shut off and then checked everything before it kicked on again.
      • #18
        ^ Excellent
        Sent from my USCC-C6721 using Tapatalk
        • #19
          You never told us if you have a Carb or a EFI?
          • #20
            EFI
            • #21
              Where should an efi 1.3 b3 be times for best mpg
