Head gasket replaced, wont idle HELP!
  • Head gasket replaced, wont idle HELP!
    I just replaced my head gasket this weekend, timing seems to be right as rain. If i give it gas it will start, but it doesnt seem to want to idle. Any places to start my trouble shooting?!
    Any help is appreciated.
    thanks!
    Jake
    Jacob
    Vacuum leak. Do you have the intake pipe hooked up if it's an EFI? (the pipe that goes to the filter on fuel injected motors).
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      yes, also the MAS is hooked up. Some folks here in the shop said to check the vacuum lines and PCV valve? sounds reasonable!
      Jacob
