I have a 93 Festiva (L?) Seems like the humming is coming from the front passenger side, starts getting near unbearable at around 62 and again around 73. The speed where it gets the loudest does change with the inflation pressure of the tire, what I mean is with a lower pressure in the tires, both those speeds are lower. (prolly just confused the heck outa ya, but hang in there plz) When turning right even the slightest, the sound goes a way and conversly, when turning left it gets deafening. Put the car in the air and wiggled the tire left to right and top and bottom (in and out) and it was tight. with the front end in the air, run it up to about 35ish and crank the wheel all the way one way and all the way the other, with no sound. Doesnt seem like the wheel bearing because the wheel is tight, and not the u-joint because there was no noise in the air, dont think it is the tires because the same thing happend with my Duster and rotating the tires didnt help. Sold that car before I could figure it out. I will rotate them when I find the tire iron agian.. already broke 2 ratchets on the darn lug nuts. Anyways, it has been making this noise ever since I had it.
Sorry about the long read, hope someone can help.
RJV
RJV
