Gentleman:
New to the site and am in need of some techno help for a 93 thats kinda chappin my henie,LOL!
Here the deal my girl friend owns this 93 festiva, claims she paid a guy 2K to rebuild motor but never finished the smog for CA registration.
It sat for 3 years in her ex's yard and then we decided that was a bad place for it.
Went to AAA and ante'd up past due fees and got some one days to move it around. First time I see this thing is a week ago!
Hard to start, won't idle, but once warmed up no issue with starting. changed oil and filter sent her to smog it,....it failed.
Timing off, air filter system wrong, and to make matter worse it's leaking like a sieve fron the rear main!
So here's what I could use help with:
Crank pully timing marks, I found one mark painted blue, not white, on the current pulley. I can't make heads or tails of the "scale" built into the lower timing belt cover. Book says two marks on crank pulley.
Could sure use a picture of a pulley off the car with both TDC mark and 10 degree plainly marked
Could sure use a picture of the lower timing belt cover off the car with the correct "pin" / time to mark plainly marked.
My new Haynes manual shows none of this, nice buy, LOL!
I bought a complete air filter system off E bay which included the hoses and reserve air chamber so I should be able to "clear up" the wrong intake issue.
A plus for this is I believe the smog hoses are set up worng and this thing is actually pressurizing the crank case forcing oil past the rear main. I hope set up correctly our leak will go away.
I have a new throttle body gasket on order and paln to replace a bunch of vacuum hose, you can hear the leak and the idle smooths right up with a spritz or two of WD 40!
Once I get this info I should be able to straighten this puppy out just getting frustrated with the lack of info on the net!
Lots of hotrodded Festiva's by the way just nothing that I need to fix this one.
Car runs good once it's warmed up, if I was in another state I could time by ear but here in Cali it has to be spot on or they won't pass the visual, so I think her "mechanic" did the engine right He either had the same problem I had or just last interest in it.
In any case I got 900 of my hard earned bucks in this thing and need to finish it so it can be sold!
Any and all help appreciated.
