Car reluctant to go into 1st and 2nd gears at times. I suspect synchromesh bushings but want to make sure the
clutch is working first. How can aperson tell if the clutch is being fully engaged when the clutch pedal is depressed?
Checking the pedal hegiht and freeplay against the Haynes manual I think Mr Haynes has it wrong. He says the
(shortest, see photo in manual) distance between the pedal and the floor should be 8 1/4" but mine is only 5 1/2".
My clutch pedal is almost even with the brake pedal which is 5" from the floor. At 8.25" I could not get my foot up
on the clutch pedal. Also he says the pedal freeplay should be about 1/2" but mine is 1". However checking under
the hood the freeplay is what he says. He should not give the same freeplay for the pedal in the cab and the pivot
under the hood because the leverage is so different. Has anyone else noticed this or am I reading it wrong?
A friend tells me I can get the car to go into gear by "double clutching". Does anyone know what she's talking about
and why that works? (I'll look it up but it would be nice to have it here in the repair forum.)
I'd hope to buy some time put together a plan to fix the problem.
Thanks.
Thanks.
