I have 93 manual festi will 155,000 miles on it. I drive roughly 100 miles a day with it to and from work. I recently replaced the tie rod ends on it (about 2 months ago). When I am turning right at high speeds, like when you are changing interstates, I here a ratcheting noise. It gets louder with the harder you turn the wheel and stops when you straighten out. I did have to remove the anti rattle clip from the brakes because it rusted off (does not sound like the brakes) Ball joints were fine 2 months ago. Any ideas? Could it be the ball joints?, CV joint, Bad bearing, any number of other things
Racheting noise while turning corners
I agree with the other gents on this one. If in fact it is the CV axle You can get one side at your local Autozone for $59.99 with a $22.50 core. I just replaced both of mine, and found that to be the best price out there.90 Festiva with Brand new B3, 5spd
92 B6 Festiva, 5spd
I looked into diagnosing CV joint problems last year. From what I read they are more likely to make noise at low speeds. One way to check is to make slow tight turns and listen. I tried it in a parking lot driving in tight circles.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
