Turn Signal Switch
  • Turn Signal Switch
    Turn signals & flasher went out today.
    They work intermitent.
    All bulbs & fuses are good.
    Its got to be the switch.
    Rockauto has them for the '88-89 Festy, not listed for ant other years.
    My question is will the '88-89 switch fit my 1993?
    '93 Green L - ' Tiva
    I'm guessing the '88-89 is orange type, can't tell in pic.
    So after more exhaustive search, the answer is no/sorta.
      Do you mean the relay?
        Switches won't interchange Plugs different.
          Hello.
            Thank you brave ! ! !
              I'd pulled one out of an old Mazda to give Farmstiva intermittent wipers, and the other side had cruise control. Would be worth putting that one in if I had a cruise control unit to put into Farmstiva.. but no luck finding one so far..
              Carz:
              '09 Ford F-150
              '80 Chrysler LeBaron Town and Country
              '80 Volvo 240 2dr coupe
              '93 Festiva GL
              225996.9 kilometers = 140428.0 miles on the odometer
              ...and definitely more soon..
