92 Festiva L - Backing Plates Needed
  • 92 Festiva L - Backing Plates Needed
    Hello - lost my rear brakes on my festi last week (bake fluid lost). My mechanic tells me I need a couple of backing plates.
    Are any of these available from anyone?
    Thanks,
    Kevin
    Not that I know of. Maybe 4green has them... Either way you might be able to get away with just fiberglassing over the (presumably rusted) area. They aren't very structural. They just shield the drum brakes and hold the shoes in place.
    Sent from my SCH-I605 using Tapatalk
    1990 White L-Plus 5-speed rust-machine
    Scrapped
    1991 Blue L 5-speed
    daily driver, intermittent project
    1993 rustless wonder
    A shell, awaiting suspension, brakes, and B6T
      "4green"? is that his id? tried a private message and site said not found..........
        4green is a website
        Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
        Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
        Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
        it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
        Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
        TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
        bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
        '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
        SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
        R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
        R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
        R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
        R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
        R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
          ah...ok....thanks
            Originally posted by Basement_Modder View Post
            ... They aren't very structural. They just shield the drum brakes and hold the shoes in place...
            I would say that IS pretty structural. They also hold the brake cylinders in place. Imagine if one was to let loose while braking. Could cause a definite loss of control in various ways.
            If they are rusted through or weak in any spot, I'd replace them.
            -Bryant
              not structural? just the wheel cylinder is bolted to it and the shoe pins and keepers. and the shoe edges slide on the flats. 4G has no backing plates but they do show an entire replacement assembly for just $73. you get the spindle, backing plate, wheel cylinder, parking brake lever, brake shoes and shoe hardware. everything shown in the outlined area. for LHD cars, part #s are: RH - KK15026980N. LH - KK15026990N.
                Hello F3BZ,
                Thanks for the info. Your comment mentioned "LHD" cars; what did you mean by that?
                Thanks.
                  Left hand drive. Over seas they have RHD, right hand drive cars. Meaning they drive from what would be our passenger seat.
                  Jerry
                  Team Lightning
                  Owner of Team Lightning
                  93 L Lightning. BP
                    ah...ok. thanks,
                      How do I know that those part numbers noted by F3BZ would work/fit for my 92 festi?
                        cuz i'm an Eagle Scout. if they don't fit, i'll buy them from you including the 4G shipping charge.
                          Perfect. Thanks.
                            I'd LOVE to buy these as my shoes are cracking apart, my wheel cylinders are just starting to leak, PB levers have seen better days (lubed them up real nice but they still stick every now and then) and of course my backing plates are starting to rust badly.
                            Problem is I'm to the point I'm not sure the car is worth it. Body cancer is just starting to spread and while the car is dependable for now I honestly can't see it holding up more than another year or two. As a result I just don't want to put any money in it if I don't have to.
                            Grr... decisions, decisions...
                              OK so I bit the bullet and bought these, along with a few other small things that otherwise wouldn't have been worth the shipping.
                              Came with everything except the spindle.. which is fine I didn't need those anyway.
                              Anyway, here's what you get with the above part numbers:
