hmm ok this is probably not good
  • hmm ok this is probably not good
    Noticed an oil leak this week.. front main seal on the B6.. what worse is that when I rev the engine it looks like the crank pulley is coming out about a 1/2" lower the rpms it goes back to original position. I checked the pulleys to make sure they were tight and flush still...
    hmmm what did I break?
    sounds like you wiped the thrust bearing [part of the main bearings] . if the engine was used could have been abused - lot of speed changes , poor maintainence
    91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
    93 u.s. festiva gl 222000 mi. bad engine , parts car [sold]
    1981 ford F-100 400000+ miles ? , looks rough - runs good
    1963 1/2 Ford Falcon 4 door base model , 106000 original miles , second owners
      it was a crate engine has about 35k on it.. speed changes, yes. Poor maintenance, no I have been pretty diligent about oil changes, etc.
      I would assume it's been going for a couple of years, but adding the 2nd alt may have just sped up the process.. looks like the BP's getting closer to going in than I thought. :?
        Time for a BP swap so you can make Ohiostiva!
        93 GL modyfied!!!
        :fish:
          GIT-R-DONE
          You should have plenty of time to complete that swap
          HD2500 Duramax Chevy
          Z28 LS1 power 500 +
            time, lol sure... parts, no.. still need mounts, ecu, wiring harness, exhaust and that's if I put it up against a Festiva manual trans.. plus since this is my daily driver, it means I need to get another Festiva roadworthy and legal before I can even tear it down.. In my job I drive at least 500 miles a week.. I am "on call" so when someone calls, I gotta fly. Now if I had a couple of Matts down here willing to help, it'd be different. Help seems to dissapear around here when work is involved..
