O-Ring Size
  • O-Ring Size
    I am nearing completion of the rebuild of the B3 and am nearing time for the install. The only thing lacking on the engine is replacement of the rubber O-ring on the bypass coolant pipe that comes off of the water pump and comes around the side of the engine with the exhaust manifold. It is the O-ring that is on the portion of the pipe that slides into the pipe from the water pump. The boys at O'Reilly's as well as AutoZone could not match up the O-ring.
    Can someone tell me the size (dimensions) or part # for the O-ring?
    Thanks.
    KKY0115287
    Anyone know what Aspire part F4BZ-9229-C is for? Is it an O-ring kit?
      [QUOTE=bravekozak;656956]KKY0115287
      QUOTE]
      Thanks for the part #. The local Mazda/Kia dealership has 3 in stock @ $1.61 each.
      Thanks again.
