I'm new to the forum and I am going to go get a red festiva 1.3L with 220,000 miles for $100 and I'm trading an xbox. The car has a bad head gasket(smokes bad, water in oil) and I was wondering if there is a how to thread any where? And is this a interferance motor? Is it a hard job to do? Thanks!
Head gasket replacement
Welcome to the forum, Jensen - and welcome to Festivas.
The Mazda B3 engines (what Festivas have) are non-interference, so if the timing belt flies off, throw another one on and keep going.
As to your other question, I'm sure someone has made a thread at some point. If you try to use the search function at the top-right of the page, it can yield quite a few results. If there's too much, try putting it in quotation. Such as, "head gasket", ect. It'll narrow the results down quite a bit.
I haven't done a HG yet so I can't really help there. Just wanted to welcome you aboard! Also, we want pictures!#!#@
White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
+1 on getting a Haynes manual. Pictures, explanations, torque specs, etc.; anything you don't understand after consulting it, you can ask here. Two specialty parts only--a torque wrench, and a 12-point 12mm socket for the head bolts.Originally posted by 25Horseplay View PostHead gasket is pretty easy if you have basic mechanical skills. best bet is to get a manual at your local auto parts store.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Nice! I don't see the usual rust either so it looks like you have a solid car to start with. It'll be worth every penny you put into it.
Make sure you get the head worked over at a machine shop, don't ever pull a head and put it back on without having a machine shop plane it first. For the price and with that many miles on it go ahead and get a 3 way valve job and do the valve stem seals too. It will feel almost like a brand new engine when your done with it. Shouldn't cost more than $150.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Once you get the timing cover off, cut it so that you don't need to use that bolt hole. Or just don't put that bolt back in. Many people also cut the face of the timing cover so that it won't contact the water pump pulley.Originally posted by shadetree View PostNope! But there is a bolt hiding behind the water pump pulley .90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
with A/C. Got a good deal on it and am excited to get it on the road again. I need seat covers and am going to put in new black carpet after I get it running good.
