I have blow by and am only getting 39/40mpg after a ton of replacement of parts and what not. I have come to the conclusion that my rings are bad (low compression test) but when I do a vacuum test it stays in the 19 range but does flutter but not more than an inch. Wouldn't the vacuum test show bad compression as well? 93 5 speed. I still can't shake the feeling that there is something else going on that is costing me the gas mileage I should be getting.
Can you tell by just a vacuum test if you have bad rings or not?
My car dies when one vacuum hose is removed. Don't know if that applies to all hoses at all connections.
Check the permanent thread about vacuum diagnosing at the top of this forum.
I recall it is an indicator for worn or dirty valves. Not sure about rings.
Usual test for worn oil seal rings is wet and dry compression.
Cylinder pressure should not vary by more than 5% across cylinders.
You seem to have a problem there.
I once had a low reading on #3. When I removed the valve cover and
turned it upside down I could see carbon deposits above the #3 exhaust valve.
Thinking there might be carbon buidup, possibly crystalization, preventing the valve from
fully closing, I used chemical cleaner which must have dissolved the carbon because
the compression went back up to within 5% of all the other cylinders. Has stayed up.
Good luck.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
