Brakes are self-adjusting so set the toothed cam at the shortest length you can (should be self-apparent what that is) so that you can get the drum back on and over the shoes. Applying the handbrake multiple times and stepping on the brakes in reverse will speed up the brake re-adjustment.
Emergency Brake Staying Engaged?
Clean it thoroughly then press as much grease as you can into the mechanism. Then wipe off all the excess. and reinstall. Repeat process approximately once a year (or more for us Ohioans). Enjoy your new-to-you ebrake system. lol-Bryant
Muriatic acid next time. Soak them till they are clean again. It's just watered down hydrochloric acid "safe" for sale at a hardware store IIRC. I know they have it at Lowes here.
Much easier than elbow grease and PB blaster.Any difference that makes no difference is no difference.
Using the parking brake will prevent rust from seizing it up. No need to treat other than a bit of grease on installation.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
I use my parking brakes all the time when they work. They still eventually seize up. Not sure why.Any difference that makes no difference is no difference.
Bert - Thanks for the answer and for writing it so clearly!Originally posted by Bert View PostBrakes are self-adjusting so set the toothed cam at the shortest length you can (should be self-apparent what that is) so that you can get the drum back on and over the shoes. Applying the handbrake multiple times and stepping on the brakes in reverse will speed up the brake re-adjustment.
Gomez - Don't think I can get much grease on/in/near the 2 pins that allow for rotation but I'll do my best.Originally posted by Gomez View PostClean it thoroughly then press as much grease as you can into the mechanism. Then wipe off all the excess.
Ahhhh...good to know. Actually have some here at the house.Originally posted by sketchman View PostMuriatic acid next time. Soak them until they are clean again.
OK, no paint. Thanks!Originally posted by WmWatt View Post.....No need to treat other than a bit of grease on installation.
I appreciate all your inputs. Right now I consider myself qualified to hand tools to a mechanic, lol, but I'm learning!Last edited by Twistiva; 07-02-2014, 09:49 AM.88L - 'Twistiva' - 'The Fusion of Man and Machine'
93L - 'Vextiva' - Airport Car
Hi Dan... you need to empty your PM mailbox. It's full again!Ian
I would venture to say .... you are not loosening them up enough. I make them loose as a goose. Beat them with a hammer til it spreads the rivets a little that hold them together.Originally posted by sketchman View PostI use my parking brakes all the time when they work. They still eventually seize up. Not sure why.
Apply hi pressure grease. I use this because the hi pressure grease doesn't break down easily with exposure to the elements.Dan
Guys -
E-brake on my daughter's Festiva appears to be working fine now. Thanks to all who helped me get it fixed. Sorry I can't post any pix, I'm over my size limit. (How do you delete any from old posts to make room for new pix?)
A word to the new mechanics....
1st, do NOT put grease on the spindle itself. Maybe just a light film to help slide the hub on the spindle but don't glob any on the spindle like I did at first. When taking the hub off the spindle I saw grease on the spindle and thought "Ahhh....grease on the spindle. Hubs spin. The spindle will need to be re-greased when I put the hubs back on." Wrong. The hub does NOT spin on the spindle. The bearings spin around the spindle, not the hub itself. The grease I saw on the spindle when I took off the hubs was residual/excess grease from the inner hub / where the inner and outer bearings are. Bottom line: grease on bearings = good, grease on spindle = bad. An experienced shade tree mechanic told me the reason is excess grease on the spindle can heat up and melt/drip down into the brake shoes. Not good.
2nd, the spindle nut requires very little torque before you stake it. The shop manual, in my opinion, sucks at walking you through that process. It says 18-22 FOOT pounds but that is just to seat the bearings. Then it says to back it off (the spindle nut) until you can literally turn it by hand. Then it walks you through an elaborate couple of steps involving INCH pounds and "bearing pre-load" and when you're finished doing the math it says to then torque the spindle nut "slightly" (or something like that). What the heck is "slightly"? Any comments on how tight to get the spindle nut before staking by experienced Festy mechanics would be appreciated.
Thanks again! :thumbs_up:Last edited by Twistiva; 07-15-2014, 04:16 PM.88L - 'Twistiva' - 'The Fusion of Man and Machine'
That process is hard to convey in words. It really is just a feel kinda thing. I have spent the last 10 minutes trying to write something for ya. I keep on erasing everything I write just so I don't get made fun of by everyone else. Sorry, dude.-Bryant
What Ive been doing is tightening the nut and spinning the drum at the same time.Get it so I know I have good pre-load,then back it off @ 1/8-1/4 of a turn.Originally posted by Twistiva View PostAny comments on how tight to get the spindle nut before staking by experienced Festy mechanics would be appreciated.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
After the wheel is back on it should spin freely without any play in the bearings. Grab the top of the tire and push and pull to test for bearing play. That can be done any time with the wheel on the ground. Test drive the car and feel the hub to see if it's heating up from too tight bearings.
Earlier ths summer I heard a slight noise from the left rear. I walked around to the back, grabbged the top of the tire, and gave it a good pushing and pulling. There was a bit of play. I removed the dust cover, tightened the axle nut, and re-staked. I could see where the axle has slipped past the earlier stake mark. I have the staked nuts, not the cottered nuts.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
