I have a 91 ford festiva gl. So I need to replace my front main seal. I have all the belts, pulleys, and timing belt cover off. Now all that is left is to remove the crankshaft timing gear, but dont know how to. Any suggestions on how to remove it to get to the seal?
HELP!! Front main seal
Rent a steering wheel puller at a McParts store. Works good. Use metric screws to screw into the pulley. Tighten center screw. Wa La off comes the pulley.
I have had those pulleys come off by hand, and others had to use the puller. I kept the puller, the rental was $20 so I just kept it.
I knew I would need it again in the future.
Welcome to the forum!
Go to the form section and introduce yourself! There is a section for newbies!Last edited by drddan; 07-10-2014, 11:00 PM.Dan
