Blue (92 L 5 speed) has been experiencing the dreaded stalling and idling issues. It seams to idle fine on level ground but when slowing to a stop on a hill, or coasting down a hill, it stalls. It idles low too, around 4 to 6 thousand rpms.
The engine was put in around 4 months ago. It came from a junk yard. It ran fine for a while. I have given Blue new spark plugs, distributor, rotor, & wires. I even switched out the air meter. I noticed a little oil in the air intake. I had replaced the PCV valve too. The engine has a lot of power and runs great otherwise. Before Blue was mine, it had sat for several years & had insect nests in the engine compartment, remember, the engine that's in it now I got from zoomzoom and was put in about 4 months ago.
What else could it be? Fuel filter? worn piston rings? bad fuel pump?
