1991 Ford Festiva
  • 1991 Ford Festiva
    Hi, I am wondering where the pump for the windshield wiper fluid is located. I cant seem to find it.
    If I remember right it should be in the driver side wheel well near the bumper. You need to remove the tire and the plastic wheel well guard to get to it.
    - Form should follow function...
      that's correct that's were we found mine
      92 GL was red automatic Ms Va., now Zinc Yellow
        Head out to your car and remembering what SiliconSoul said, now lay on the ground and look up, you should see the bottom of the windshield wiper fluid tank.
          it's attached to the fluid reservoir itself with a band clamp.
