Car is a 92 L 5 speed if it matters. replaced the dizzy because it was leaking internally. As well as the front seal, oil pan gasket, timing belt( yes it's on correctly, I'm 1000% sure). Got the car back together and try timing it and no change in timing with STI port grounded to chassis. My STI port is yellow/green, not yellow/black stripe like everything says it should be. Every manual says to ground it. Just never states where to ground it to. I grounded it to the chassis thinking a ground is a ground. Somewhere I saw that someone grounded it through the STO connector. The car hasn't ran in 3 weeks because it runs so horribly and has NO power. I've searched this forum hi and low to find and answer to prevent making this thread.
So my question is, is my STI port correct and is a chassis ground sufficient enough? If not, what's my next move?
as far as the pic goes. wire colors are as follows.
STO connector
top center- yellow with black stripe
top right- yellow with white stripe
bottom- blue with green stripe
STI port- yellow with green stripe
(not pictured)there is also another yellow with green stripe wire with a flat spade connector next to the obd1 port. spade connector looks factory.
STO connector
