rear drum grease seal
  • rear drum grease seal
    93 festiva, rear drum grease seal, which way does it go in? Concave side in towards the bearing or out toward the spindle, I think it's concave on the bearing side but I want to make sure. I didn't look at the old seals orientation before i took them out :roll:
    the inner lip on the seal goes toward the lubricant. or the flat portion between the inner lip and outer flange faces out , whichever is most obvious to you.
    91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
    93 u.s. festiva gl 222000 mi. bad engine , parts car [sold]
    1981 ford F-100 400000+ miles ? , looks rough - runs good
    1963 1/2 Ford Falcon 4 door base model , 106000 original miles , second owners
      Ya that's what I thought, I just wanted to be sure, thanks
