I have a 91 Festie with a/c, p/s and an automatic. Just prior to driving to Westiva I rebuilt the B3 which now has about 2500 miles since the rebuild. Since the rebuild and on the trip to Westiva the car is only getting 30 mpg instead of the 40 mpg that it used to get with the old engine. The car runs fine, no missing, no stalling and no hesitation.
My problem is that the CEL randomly flashes on for about 5 minutes and then off. I replaced the O2 sensor and thermostat during installation of the engine. The temp gauge usually runs about 1/4 of the way.
I just grounded ST1 and read out the codes: 8, 15 and 17. I located on the forum where 8=air flow sensor, 15=O2 sensor and 17=O2 sensor.
Is it possible that there is one component that is bad that is causing a domino affect resulting in 3 codes?
How do I check out the parts (O2 sensor, VAF)? Why 2 codes on the O2 sensor?
Thanks.
Thanks.
